Greenhumber
Thread starter- Joined
- Jun 30, 2021
- 7
Hi all. I've got a 1972 Johnson 50 hp. Model# 50ESL72C.
Last year it had a very intermittent miss at full throttle. Didnt think much of it.
This year its a constant miss from 1\2 to full throttle.
I have cleaned and rebuilt the carbs.
Installed a new fuel line.
New spark plugs.
I had to install a new ignition switch this year as well.
Top cylinder has 148 psi
Bottom has 145 psi
It wont idle properly either. Ill set the idle and itll be good until I back it down from running on plane and itll idle down so low it stalls.
For the motor to run smooth at an idle the top slow speed needle is turned out a half turn and the bottom is turned out one full turn. I know this isnt right either.
Also, if the motor sits for a few days it is really hard to start. But once it is started it has no problem starting.
I am lost as to what to check or do next.
Any tips would be appreciated.
Thanks!
New spark plugs.
Bottom has 145 psi
Thanks!
