Engine coupler woes
flashback
I removed the gimbal housing today and got a bit deeper, I can't find any splines on the coupler. This boat is becoming more and more discouraging. I suspect I know the answer but just thought I would ask. Can a coupler be swapped while the engine is in the boat? I don't have the equipment or location to do an engine removal. Currently working on the side of the road in a circle in front of my cabin.
Ayuh,..... Ya need a Ft. or more access behind the motor to change the coupler,....
'n that's a bare minimum, if there isn't more "Boat" in the way,.....
Build a bridge from gunnel, to gunnel for a lift point,...... ;)
Nextelbuddy
The splines don't start for the first 1-2 inches of the coupler.
Like Bondo said it's all about space and if there's a transom in the way it's going to be hard.
Here's a pic of my engine with the coupler on and a closed up showing there are no splines visible for first few inches.
flashback
I was afraid that would be the case. 20 years ago I swapped out the motor in my 79 chris craft and you were there in spirit... back then I had a place to work and I rented a cherry picker to pull the engine. but just not sure I am up to that these days. I need to study it a bit more. I actually got it to the launch ramp on it's own power but just at idle so the drive was working.
flashback
Thanks for the photo, I didn't know the splines didn't run the entire length, It gives me hope that it still may have splines in it. Like I said in my previous post once I got the engine running I was able to get the boat to the ramp but I didn't push it...
flashback
Thankfully a false alarm, I have a hunting friend who loaned me his bore scope and I have plenty of splines and they all have flat tops. The gimbal bearing was so trashed that paranoia set in. I have some high pressure moly graph grease which I use on my lift gear which seems like a good choice for the splines.
