1986 Mariner 40 HP Model 40ELO Fuel Pump
64Amphicar
I have a 1986 Mariner 40 HP Model # 40ELO. I am trying to find the correct part # for the fuel pump. Is it a Yamaha or Mercury fuel pump? Thanks for any assistance.
Yamaha built.----Fuel pumps are simple to diagnose and repair.-----What is your motor doing / not doing ?----What trouble shooting has been done ?
64Amphicar
Just purchased the engine and it fired right up and ran good. Then it just cut out and will not start. Cleaned fuel filter, new fuel tank and lines. Removed fuel pump and opened up, a lot of stuff trapped inside.
Clean fuel pump bits.-----Install new water pump impeller.
64Amphicar
A new water pump has been installed, the springs, diaphragm and other parts inside pump do not look so good. thought it be better just to replace the pump. Just having trouble with the correct fuel pump part#??
Any pictures of the pump.----There must be a dozen pumps off Johnson / Evinrude / Mercury that could be adapted.
64Amphicar
Photo of the fuel pump side.
I see the fuel pump available at $125.92 -----Hurry to your local Mercury dealer and order one for your motor.
64Amphicar
Is that the
Part Number
43113T
Mercury Quicksilver
Or is it the Sierra Part #18-7334 or Sierra Part #18-7349. These two also come up as fuel Pumps for this engine.
That is the question I need help with.
