DeepCMark58A
Thread starter- Joined
- Aug 17, 2015
- 3,576
So noticed last night pulling my son when he was trying to get up on 1 ski, that it was not going as well as it could. What would be the ideal prop to pull skiers better?
I found "crashes" hard on the body at 36...liked 30 better. I ran a 17P 13+ diameter SST (Staninless Steel Teflon coated OMCs first SS prop) on my 18' Caravelle tri-hull open bow with 125 engine rated HP 1972 Johnson engine....equivalent to your 115 prop rated pretty much. I had no tach either but with a light load you could tell engine was running high RPMs (singing) and getting up on plane wasn't a problem. It ran 39 with just me...I remember well as I wanted 40 and with that family boating prop I wasn't going to get it. As a matter of fact, as a stunt at a company picnic, I was able to get 5 people up on skis for a couple hundred yards before one fell off.You will want to pull him Slalom at 36MPH. Obviously the prop with the most power for skiing will run 36MPH in the center of the max RPM range.
What is your max RPM and top speed now, when not pulling a skier
Yes there are but need to know your current prop and wot rpm to make a reccomendation.The boat is a lund Tyee the boat is at maximum hp rating, the young man only has 1 foot in the binding. I do not know what the current prop is I just know that there is a better prop for pulling skiers than what I have on the boat.
You mean the guy that's had boats all his life, that's worked with hundreds of customers regarding a "best" prop over the last 20+ years?The boat pulls much better now, funny a guy working retail that had first hand experience pointed me in the right direction.
This vs. somebody that's never had a boat, but scored a sales job in a bait shop?
The issue is, separating those like the first guy, a shop owned by a guy like the first guy, a shop that employs a guy like the first guy, and those out to make a buck using seasonal help paying minimum wage..... Best of luck!
My point exactly! So you spent 100. or more not knowing this? That's a pretty significant gamble the way I see it.I guess I just got lucky, don't be offended. It isn't rocket science. Plus you have zero idea what the guy's career was before he took a retirement job at Cabela's.
