Problems with accessorys
Mars8824
Purchased a 1993 tracker magna 17 ans the engine starts and runs just fine but there is problems with the switch panel when ever you switch a switch on. it will make a beeping noise but not turn the item on for example the bildge pump or the live well pump it dose the same thing with the depth finder you will plug it in then press power it will beep but not turn on looking for some advice.
dingbat
What is generating the beep? Bilge pumps and live wells don’t beep.
Fish finder will beep at “boot” but that it
More than likely bad or dirty wire connection(s). Start at the battery and clean every connection as you move forward
mr 88
Your going to have to trace your wires from the items your trying to power up. Most boats will sound a alarm when starting them up. One of my boats keeps sounding after it starts , have to manually hit the alarm button that is on one of the gauge clusters to turn it off. The other one auto shuts off after it fires up.
mike_i
Did you buy the boat with this problem or is it a new problem? Brake out the voltmeter and start tracing the wiring/voltage issue.
