Cannot find the right propeller 225 OceanRunner
cobbcfi
My 1996 Johnson 225 needs a new prop but everything I am getting is to short in depth for the prop shaft.. The spline washer is 1/2" from the prop and the propeller si out of the exhaust hole.. Got the 14.5 by 21 pitch but the 3 time now its to short..
Anyone have a link for the correct prop?
Faztbullet
The new models use a different prop washer as shaft size is different ..Make sure it fits all the way down on taper
dingbat
What props are you looking at?
I’ve had no issues finding props for my 1997.
Don’t remember if I had to change thrust washers or not.
Used Merc Flo-torque hub in a 15x15 Merc Enertia. Hub looked long until you torqued the nut down on the shaft to seat the hub in prop
dingbat
Used Merc Flo-torque hub on a 15x15 Merc Enteria. Hub looked long until you torqued the nut down on the shaft to seat the hub in prop
