- Jul 18, 2011
- 19,091
Greetings,
An unusual issue . . . It appears that the impeller vanes in the sea water pump of my port side engine have (somehow) flipped themselves to the wrong direction.
All was good at the end of last season, but this year when I started the engines for the first time, I noticed the sea water pump of the port engine was not turning. The starboard engine is fine (new impellers last year).
I initially thought it was the belt had worn out, but upon further inspection the pump will turn the opposite way, but gives a lot of resistance to the point of not wanting to turn at all the correct way. Using my boroscope, I can see the impeller vanes and they are pointed the wrong direction. I am thinking maybe the engine rotation kicked backward when I shut it down last year ???
Anyway, other than taking the whole pump body apart, any ideas, tricks to get the blades to flip back? I did not want to force it . . . and I applied a good amount of force/torque to get the impeller to turn the proper way . . . it was a no-go.
Headed to town to buy a new impeller . . . just in case.
