Volvo Penta wiring change
llewis01
I have a 1994 volvo penta 454. I'm changing the alternator to higher amp. My old alternator is a presolite 5 wire and changing to a 3 wire alternator. My question is what the wiring diagram should be to do the change? I need the higher amp alternator to power all of my electronics.
Any help would be great.
alldodge
VP keeps the pump ON thru the ALT (Green wire thru diode). If motor dies the ALT stops and power thru the ALT to the fuel pump stops
You want to wire it up as a Merc and may want to add a oil pressure switch. Starter powers pump while cranking and and purple wire keeps it going when running
My thought is to remove the fuel pump relay and just use the oil pressure switch
Disconnect fuel pump relay
Disconnect Green wire from ALT to fuel pump relay thru diode, cap off
Disconnect Yellow/Red wire to fuel pump relay
The Yellow/Red to relay goes moves to fuel pump hot side and oil pressure switch normally open (NO) side of oil pressure switch
Purple ignition wire goes to other side of oil pressure switch and The excite side of the ALT. Also connect to electric choke on carb
Connect Red/Purple from start assist relay to Field side of ALT
llewis01
I don’t have a yellow/red wire to the relay.
alldodge
Never said which model
Is your wiring similar to this one?
alldodge
By model I meant the motor model, is it a GL, GS etc?
The GL wiring above has a Yel/Red wire going to a diode to the fuel pump relay
Below is a Merc manual to electric fuel pump. The Yel/Red going to the inside small post on the starter, is used for one side of the switch. In your case it would run to the FP relay. The Green wire is removed and the Purple wire is feed to the same FP relay point
llewis01
It is similar to mine. My is a Glimda model. Sorry about that.
Thanks
This looks close to ours but we can’t tell where the yellow changes colors because it goes into a taped wire bundle.
llewis01
Volvo Penta wiring change​
Unwatch
L
llewis01​
Seaman​
Reply
Report
[IMG alt="alldodge"]https://forums.iboats.com/data/avatars/m/144/144589.jpg?1602078948[/IMG]
alldodge​
Supreme Mariner​
Like Reply
Report
L
llewis01​
Seaman​
Reply
Report
alldodge​
Supreme Mariner​
Like Reply
Report
L
llewis01​
Seaman​
Thanks
Reply
Report
alldodge​
Supreme Mariner​
Like Reply
Report
L
llewis01​
Seaman​
Thanks
llewis01
Got it wired up with using a Holley pressure switch. When you turn on the key, the fuel pump runs. I don’t think it should do that.
alldodge
Correct, you don't
The common should go to the pump
The wire that is hot when key is on, should go to the Normally Open (NO) side (the Purple wire)
The side that goes hot when cranking, should go to the Normally Closed (NC).
If the fuel pump is on the correct place on the switch, then swap the other leads, but again it should be on the Common connection (also called switched leg)
