RPM won't go over 4000
jyohe1612
I purchased a used Mercury 2002 125EXLPTO motor and I'm having an issue that it will not go over 4000 RPM. Spark and Compression is good, pulled carbs and checked the Reed valves. Ran clean fuel through it and still getting the same results. Anyone have this issue or suggestions on a fix.
JDusza
Unfortunately, the couple exploded views that I use as reference require a serial number as input. Any chance you can get us that?
I have seen incomplete travel on the ignition advance. Without knowing your configuration I cannot say that this is your problem. It's just an idea. I mention it only because you said you got the engine "used". In my case, someone had replaced the design intent linkage rod which ties the throttle to the advance with something off their garage shelf. That was my "used" engine. lol
J
What pitch prop and what boat is it on? It could just be overpropped.
jyohe1612
J
Yes the serial number is 0T552683
jyohe1612
I have it mounted on a 1997 Starcraft 190 Superfisherman. I will see what the prop is and get back to you. The marina that was working on the motor replaced the prop because he dinged the one up that was on there.
jyohe1612
The prop is 13 1/4 x 17
Faztbullet
Is it stuttering like mechanic stated or runs good but no max RPM?
jyohe1612
I changed the prop to the 13 - 3/4" x 15" and didn't notice a difference.
kytooner
I was going to say try different tank and fuel line but I see he tried that. Might try it again with new hose just in case he didn't try the new hose part.. But reading through his notes he talks about blown gasket and water on the wrong side but doesn't report it repaired. What about that
jyohe1612
The blown gasket was repaired.
JDusza
May not be running on all cylinders ... ?
Is it worth trying to pull each spark plug lead while running and see if performance changes? If you pull a wire while running and operation changes, then that cylinder is working. If you pull a wire and nothing happens, then that cylinder is dead.
Would this help? I'm currently arguing with a small Merc that shows bench test spark on a tester and plug but the cylinder function is verified dead when pulling the wire while running.
J
