How do you know what prop size and pitch to get??
danboy
I just bought a new 18' Malibu Boat to be used for fishing, and skiing. It will have a Honda 130 Hp Four Stroke Engine on it, but not sure<br />what kind of prop to get. Can anyone help me??
Hooty
Re: How do you know what prop size and pitch to get??
Yo danboy,<br />There are approx. 8.326 gazillion variables to take into consideration when proping a boat. It's pretty much trial and error. Your best bet is find someone with a similar boat and engine like yours and go from there. Wish I could be more help. Just hang around tha board and wait for a rig sorta like yours and see what prop they us.<br /><br />G'luck& c/6<br /><br />hooty
ajp
Get a service manual for the engine. That should give you several options on props, variations of diameter vs. pitch. Then determine which pushes your boat the best. <br /><br />The service manual for my engine give the factory choice, then 4 or 5 other variations that will work. <br /><br />Arlan
SeaDawg
Danboy, go to Honda's marine web site. They have performance tests for their motors. You should be able to find a similar weight and style boat test with a 130 on it. They list the prop and other specs too.
KRT
Increasing the pitch causes a prop to take a bigger "bite" of the water, which means the engine must do more work. That's why the top rpm of the engine decreases at wide-open throttle. If the prop has too much pitch, the engine "lugs" all the time, which can cause internal problems if it continues.<br /><br />Too little pitch can damage an engine faster because it allows the rpm to exceed the "red line." Over-revving an engine can turn it to scrap in only a few minutes. As a rule-of-thumb, changing 1 inch of pitch will cause an increase or decrease of 200 to 300 engine rpm.<br /><br />The correct pitch allows the engine to reach its full rated rpm at wide-open throttle, but no more. If you want to go fast in a light boat, you will want a high-pitch prop. However, you will have to reduce the pitch to get the most out of your engine when the boat is loaded.
