1978 evinrude 150
Daviddiy
Already done, also removed handle., still can't yet get behind to get the bolts behind off, long ratcheting wrench will be here on Monday
Is the lower unit a ---" hydro -mechanical "-----Oil pressure assisted shifting ?----Or has it been converted to a newer style mechanical shift?
Daviddiy
Hydro-mechanical, as far as i know. The control box has 1978 stamped on it, assuming it was the original, and not sure it would work with another LU. It also takes over a quart of LU oil to fill up, and from what i can tell the only one that does is that particular 150849S LU.
A 1995 control box with the red plug will work on your motor !
Yes it will work.!---E-bay sellers are not always fully aware of what fits what.
Daviddiy
So in my understanding, the wiring will work, but the control cables will not
Yes the shift and throttle cables will work , not a problem at all.---Not sure where you are getting your information ?
Daviddiy
Other forum, info from ebay seller and local mechanic. They had stated I would need to replace the lower unit and intake manifold.
Answer this question.----When you shift your ---" power pilot "----to FORWARD does the cable pull linkages to the front of the motor, yes or no ??----For REVERSE does the ----" power pilot " ---push linkages to the rear of the motor ?
Daviddiy
I don't know, as the control box doesn't shift forward. When it goes into reverse, it appears to go forward, but I don't have a point of reference to compare.
Never mind then-----The control boxes all operate the same way !!----The different motion for shift rod is done with linkages on the MOTOR. -----The control boxes all move the same way.
Daviddiy
So what about the cables? Do they fall connect the same? Not sure why people just trying to confuse me. Thanks for clarifying. So in theory is could use a new control box, with wiring harness ?
Correct----Sorry, I can not see , feel or hear your motor.-----If modifications have been made from factory original.-----If I had an original 1978 V-6 ( I have more than one V-6 ) then I would use a 1995 control box.---Basically plug and play !!----End of the story.
Daviddiy
I bought a brand new omc control box and wiring harness and new cables, but the new cables didn't seem to work.
What do you mean by ----" cables didn't seem to work "----Did not move correctly or maybe a simple clip missing to hold them on the linkages ?
