nola mike
- Apr 22, 2009
- 5,855
Went ahead and bought this gauge mostly to replace my speedo with a GPS unit. I'd also very much like an accurate tach as well, as I have a new engine and am trying to dial in my carb and prop. This also comes with voltmeter, fuel gauge, oil pressure, and temp capabilities. Haven't taken it out on the water yet, but have some questions about the wiring:
1. Is it (hopefully somewhat easily) possible to have the electronic gauge and my analog gauges peacefully coexist? I'm guessing the electronic gauge is sending 12v down the sender and comparing the voltage drop to a reference 12v signal, but not sure. Different than an analog gauge though. I don't want to add an additional sender and wiring for OP, fuel, and temp, but didn't know if there was another way. Not the end of the world if not, but I don't like the gauge flashing "0 psi" at me.
2. Bigger issue: Wildly fluctuating RPMs. There's a calibration setting on there, which I'm trying to figure out (the instructions are wrong), but either way I don't think it would account for the fluctuations, would it? Initially I wired it into the lug for the analog tach sender. Then tried disconnecting the gray sender wire and connecting it directly to the new gauge. Finally ran a wire directly from the gauge to coil neg. None of it made a difference.
The gauge is actually pretty cool for the $75 I paid for it, and probably still worth it for what I paid, but I'd like to get all the functions working if possible, and redundancy is always nice.
Video:
Video:
