Texasmark
- Dec 20, 2005
- 15,073
Questions:
1. How do you "hole shoot"????? Angle of the engine vs transom, what do you do with the throttle when executing?
2. What are the RPMs when you are up and running and have trimmed out for maximum speed with your normal load and persons gear in normal position in the boat?
3. What is the prop you are using....material, pitch, name if stamped on the prop? You may have to remove it from the engine to get some of the information as it is sometimes stamped on the hub not on the outer surface.
