1982 16 Foot Starcraft SS Transom Rebuild
Bsutcliffe
My 1982 16 foot Starcraft SS is tucked away in remote storage until April so I can measure anything.
I want to do the transom in April and have been planning what I need. I am trying to se if I can afford Coosa board but might have to go with Marine Plywood based on cost. It looks like I need to a 3/4 inch sheet.
Do you think I can get away with a half sheet of 3/4 or would I need a full sheet to complete the transom?
Thanks Brian
jbcurt00
Half a sheet would be 2 layers of 2ft X 4ft, not nearly long enough. Cut the other way it'd be 2 layers 1ft X 8ft, not nearly wide enough.
Can you even buy a half sheet of marine?
Dig thru some restos, lots of good info in here.
Hint, many (most?) use well sealed exterior plywood, not marine. MDO is a good substitute as well, and was easier for me to source locally, had to order it amd it was @2/3rd or less the cost of marine I couldn't even order locally. It had to be ordered online and shipping 4X8 plywood gets pricey. Exterior ply is less then half the cost of marine, but there are tradeoffs.... tradeoffs diacussed in many many topics....
Bsutcliffe
The lack of marine is why I was considering Coosa since I would have to order both anyway.
I will look through the posts about MDO.
Thanks
jbcurt00
MDO: Medium Density Overlay
Not MDF, thats complete carp.
Good 1 side is all you need.
DLNorth
Does anyone have (or seen) a reference that indicates that MDO is suitable for STRUCTURAL uses? I saw none with a quick check.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
A full sheet of 3/4 BCX, TightBond III glue, and your pick of sealer. No need to go with Marine Grade or Coosa unless you just want to spend the extra money. A properly sealed and well kept Transom will have a long life.
SHSU
