I have a 79 johnson 15. I have filled my lower unit then ran the thing in a barrel of water. I lose most of the oil on top of the water but there is not a trace of water in the oil. how can this happen? I replaced prop seals and shaft seals too.
Are you saying the lower unit is emptying the oil and filling with air ?I have a 79 johnson 15. I have filled my lower unit then ran the thing in a barrel of water. I lose most of the oil on top of the water but there is not a trace of water in the oil. how can this happen? I replaced prop seals and shaft seals too.
yep lower unit oil escapes but the oil still in lower unit is just oil, no waterAre you saying the lower unit is emptying the oil and filling with air ?
Yes the gear oil empties. Capacity is about 8-10 ounces. I have topped it off and run motor in a barrel for an hour. A lot (LOT) of clabbered oil floats on top of water. Then I drained the gear oil from the gearcase. It had about 6 ounces still in the case and the oil I drained was clean. No trace of water in the remaining oilOr it’s 2 stroke oil out the exhaust, If you haven’t lost any gear oil.
Sadly i did not. I just ordered a seal kit. I intend to replace all the seals and o rings again. Ive triple checked my part numbers and I have the right seals in place. I hope the shift rod seal is the problem, Im just really curious why water doesnt mix with the oil in the gearcaseNot sure why the basic operation / lubrication of 2 strokes is not well understood.------When piston nears bottom of the cylinder the intake ports open.----They open just after the exhaust ports.----The incoming pressurized charge of air / oil / fuel then enters the cylinder to scavenge / clean out the cylinder.-----But some of the fresh charge also escapes.------This is what you see in your tank.----And you replaced the shift rod o-ring too I hope.
Did not know how to get to the shift rod seal but I do now. I fill from the bottom with a small hand pump that screws onto the oil bottle. When oil starts out of the top hole I put both plugs back inThose seals last about 20 years or so.------Pressure test this lower unit to find leaks if you have any.----Why would you not replace the shift rod o-ring ?----A simple part of the job !----And how do you fill your gearcase.---From bottom to the top ?
I filled it from the bottom hole with a hand pump. Oil came out the top hole and i replaced top plug first then lower plugSounds like the lower unit was not completely full in the first place.
Did not know how to access that seal and wasnt a member of boatingforumsThose seals last about 20 years or so.------Pressure test this lower unit to find leaks if you have any.----Why would you not replace the shift rod o-ring ?----A simple part of the job !----And how do you fill your gearcase.---From bottom to the top ?
I did it once years ago. Recalling, dropped the LU and using a hook type tool, dug it out....as stated a quick fix. Sometimes drilling a hole in the metal part of a seal and using an appropriately sized sheet metal screw will give you something to grasp to remove shaft seals without having to dismantle anything.Did not know how to access that seal and wasnt a member of boatingforums
how would u do it Racerone? Leeroys had a chapter about this but I havent read it yet. I will read it when my seal kit comes in the mailTexas man-----You are totally wrong on the replacement of the shift rod 0-ring on this motor.
