1971 Mercruiser I-6 165 HP Tilt Trim Braided Hose Replacement
59Thompson
Good morning. Isolated the small drip to one of the four equal length external braided lines and purchased a factory replacement and a 3/8 hex line wrench. The drive is in the full down position. Is this under pressure when down or can I just put a bucket underneath to catch any drips while i quickly remove and replace? I figured to put some Kroil on the two line nuts first to let them loosen up first. I'd appreciate your advice and suggestions.
Ayuh,..... No pressure when down,.....
Crackin' the nuts loose is the problem part of the job,.....
