healey8390
Thread starter- Joined
- Nov 19, 2010
- 217
86' 110. Motor has been back together since May after doing a hone job and rings. It recently started sneezing and doing a stumble/pause when it sneezes. I found smoke coming out from what I thought was the top bypass cover on the starboard side. Unfortunately it is the case halve. I confirmed by swapping the bypass covers. There isn't a visible gap in between the crankcase but when it's dark I can see combustion. Kind of fascinating to be honest, though I'm disappointed and irritated. I took a screenshot of the combustion from my video.
When I applied the gel seal I used a lot, I thought I actually used too much. I got great bleed out though. However if you look at the pic, the top left side looks a little skinny exactly where the leak is. But with all the bleed out I'm still a little dumbfounded. I assembled using a torque wrench and I don't recall but if there was a sequence I would have followed that too.
I think my mistakes were not using primer and I "dabbed" the gel seal with the tip of the tube to build it up. Looking at the pics it kind of looks like there are low spots instead of a continuous "smooth" bead.
I know there are some threads floating around on this but I wanted to share my story and frustration. Please let me know if the "dabbing" is what caused this or whatever I may be missing. Thanks as always!!
