Deep cycle battery box
Range Wharf
Not sure where to post this question.
I just purchased a UB12350 Battery for my Kayak. Just wondering if there is someone out there that used a container to use for a battery this size.
Thanks,
Bryan.
GA_Boater
Search for Group U1 battery box.
Does your 10 footer have room for a battery and box? It must be tight inside.
Range Wharf
Yes I have lots of room. Just thought there may be a box out there that one may use. It will be placed on the opposite side of my 30lb minn koto.
Thanks for the reply,
Bryan
I would go with either AGM or Gel and not worry about the box. Battery boxes are for flooded lead acid batteries
Range Wharf
Thks Scott being a senior at the age of 72 this is a hole new thing I'm trying.
Bryan
the battery you have is a sealed lead acid battery. it needs to be mounted up-right and should be in a battery box.
Range Wharf
Thks Scott. The research I did for matching up a battery for my 30 lb troll motor should do the trick.
