- Jul 23, 2011
- 53,435
no, the boat uses a 1.5 ohm coil requiring a balast resistor for running and gets full 12 volts when cranking via the I/R terminal on the starter. that is the way the boat is wired.Does this boat use a 6V coil and ballast resistor? It sounds like it might be low voltage at the coil when cranking. Try running a jumper wire from the plus side of the coil directly to the battery and see what happens.
