Torque specs 2009 SX-A prop shaft brg holder
Pudawaa
Anyone have the specs for these two bolts ? I’ve been told 10 ft/lbs plus 70 degrees...
muc
That’s the spec for checking rolling torque with the old bolts.
During final assembly you use new style bolts and torque to 15-20 ft. lbs.
Pudawaa
I was concerned about the torque spec because the heli inserts had come loose (stripped) and the prop shaft brg housing was about to fall out ...
