Beware New old stock
alldodge
Dated August 2015, bought 2 years ago (2018) so it was 3 years old when purchased
My Rinker
Removed the belt driven fuel pump and raw water pump assembly at the end of last season. Rebuilt the fuel pump side because found it started to leak last week.
I buy Merc brand new raw water pump kits (46-807151A14), which include impeller, pump housing, stainless plate, bolts, O and quad rings. There is no way I need the bolts but it comes in the kit
Just bought 2 new kits (Dated June 2019) this year for use in cruiser end next season
Now the issue; yes I know, will he just get to the point :D
Dropped boat in the water and did not make it to the slip before it was over heating. Tied up to closest dock and spent the next 2 hours finding out what happened. The new (NOS) impeller came apart in pieces
So I replaced the entire unit with a 2019 unit, finished the idle over to my slip
Findings during repair
When assembling first pump it was harder then normal to get the impeller in the housing. Also when pushing the impeller on the pump shaft that to needed more pressure to push it all the way on
Newer pump assembly impeller bent easier (not easy) and slide right on the shaft with not issues
The inside of the housing removed showed some burning but that was expected do to no water flow
If I ever find one that is harder to install in the pump again, it will get tossed in the trash
alldodge
Isn't the conventional wisdom that the impellers life is limited by age as much as use?
Agree, but as a DoD loggy, rubber is normally good for 20 years, other rubber items even longer
Don't know what material Merc uses, but if it gets brittle in 5 years that's bad. Could be its a one off, so will try to remember if its real hard going in, toss it
Many items bought don't even have a date code, at least Merc does
There may be a reason the VP is now recommending new impellers every 2-3 years.
my guess, the impeller rubber is now like the tire rubber business..... More fillers, less rubber
zellerj
I recently replaced a impellor on an alpha 1 and it lasted five minutes, and disinigrated on the muff during the test run. I attributed it to putting in an offbrand impellor (about half the cost of a OEM one). Replaced with a Quicksilver one and it was fine. The Quicksilver one did not have a date on the package or the impellor.
dingbat
Hardly anything is made of "rubber" anymore. Most impellers are Nitrile which is a synthetic rubber.
Nitrile is superior to most elastomers with regard to compression set, tear, and abrasion resistance but does not possess good resistance to ozone, sunlight, or weather.
Nitrile should not be stored near electric motors or other ozone generating equipment.
alldodge
Mine are no where near anything like that, might have just got a bad one, stuff happens
