1994 Force 40hp - Tilt and Trim leaking down
Bevo2000
The tilt and trim on my 1994 Force 40hp motor (serial number 0E067660) is leaking down. If I bleed out the system, then I don't have any issue (motor will hold position and will not fall down). However, after a day on the lake, leak down will reappear. I think there's a leak in the seal of the cylinder because the pump works great and no fluid is leaking there. Is there a rebuild kit for the cylinder or do I have to replace it at the cost of $500 just for the part? Thanks for your input.
tg3690
Did you check out the sticky at the top of the forum titled Chrysler/Force FAQ? There are 2 posts about the T&T system including testing and repair. Good info in there.
You can also do a forum search for T&T repair....Lots of posts with good info come up.
jerryjerry05
The repairs listed in the sticky's are for the older style
T@T pump.
Your pump is a Mercury / Force made pump.
Used some parts from both.
Finding parts is gonna be tough,
The o-ring needs replacing if it's leaking at the seal.
Find the size and look for the appropriate one.
Granger and other places(Harbor Freight) sell o-rings
HF has 3 different o-ring kits. Something from them
might have the right one???
Always fill the reservoire while down.
Bevo2000
Thanks .. Yes I found the sticky for T&T and it was great.
Bevo2000
T@T pump.
Thanks Jerry, especially for the sticky regarding T&T. I have a question for you if you don't mind. I do have a service manual but it's apparently not specific for my model so I am not sure how to safely replace the O-ring for the cylinder. Do you have a link for this replacement? I can follow the sticky to replace the O-rings for the valve body because the instructions were very clear. As soon as I can buy the brass cap and plug, my next step is to perform the leak down test to determine which component is failing.
jerryjerry05
One added note:
I have 5 different spanner wrenches and
none fit the Force.
I found the deck plate tool works really well
on Mercury cylinders.
tg3690
https://www.offshoremarineparts.com/916-19-utt.html
This is the only spanner wrench I could find that specifically stated it was for Chrysler and Force tilt cylinders. Kind of pricy but worked on my tilt cylinder very well. Fits several other makes as well with several sets of pins included. FYI
tg3690
Thinkin about renting it out to try and recoup my money! Lol
jerryjerry05
I tell people that they can 'borrow" my tools on
one condition.
They leave a 100$ non refundable deposit or
let me do the work.
The Force power
WOW!!!
That's pretty expensive!!
BUT........
This is the LAST trim cap tool you will ever need.
He should of waited & they would of shipped he two for price of one & with an additional 40% off the regular retail price
info commercial :couch2:
tg3690
BUT........
Another way to look at it.....what I saved by doing it myself paid for the tool, and I will have the CORRECT tool to do it the next time! :D
tg3690
Yeah! Where is this TWO-FOR-ONE place?? LOL:laugh:
