- Jul 23, 2011
- 52,520
fuel is literally the cheapest part of boating. proper maintenance out-weighs fuel by a cost of 3:1 to 5:1
Seeing you don't use much fuel maybe don't fill the tank at the end of the year?
How hard could it be to drain the tank ? I’ve never had to do that myself but it shouldn’t be that hard .. I would think ...
It is very highly recommended that a boat gas tank be full when it is winterized, so condensation doesn't happen. I've read this on multiple websites and told this by our marine mechanic when we lived in Florida.
As usual, it it impossible to follow the recommendations of boaters with many years of experience. I personally have access to 2 marine dealers / mechanics that have more experience than I. I trust them implicitly, after having doing business with them for 50+ years. The others in town are neophytes. I guess your locals are not up to snuff either.
Three year old gas, 5 year old gas...OMG that's beyond belief. Adding automotive snake oil is even further out there. Why not just add STP treatment to it. Andy Granitelly made millions with that stuff. (sorry for the sarcasm)
If you still think your old crap gas is good, go to WalMart and buy a few 5 gallon cans and have your expert marine mechanic drain the gas into them. Then put it into your car. Your car should run just fine. Problem solved.
If you can't use a single tank of gas in a year, just sell the boat and rent one when you want.
I anxiously await next year's tribulations. In the interim, I'm going fishing...
Good Luck fishing! Just thank God we have the problem, not you. Right?
Just talked to the marine service where we take our boat and was told that they could drain the gas tank, BUT, the customer has to provide something to put the gas into. We have nothing like that! They have no storage tank for used gas, like our Florida marine service did. So, guess the so-called "old" 1/2 tank of gas will stay in and add enough new to full the tank for winterization.
The marine service told me that they probably couldn't re-jet our carb, but will adjust it. Apparently, very few-to-no boats come up here from the southern states, like Florida. We have seen some southern out-of-state license plates here, but they all look like rentals from local Enterprise Car Rental. Actually, our last car rental from them, had a California plate on it.
People have given you good info and suggestions. All you seem to do is have a answer, that is usually wrong, for what is suggested you try or do. It's very exasperating to give advice to someone that wants to basically argue about your reply or every suggestion for that matter Responding it's wrong or his mechanic told me something else. My final.suggedtion is to take it to a marina ,spend the money, since you dont seem to mind doing that.Case in point , what you dropped to have your boat moved. Let the experts figure out why you boat only goes 28 mph and lay off the whining about people that tried to help you out ,then had to read your usual argumentative reply.,then threw up the white flag. I am.going fishing as well !!
you're comparing rental cars with EFI to your motor your boat with a carburetor? seriously? EFI automatically adjusts the fuel air ratio. if you dont understand this simple principle, you wont get what we told you about your carb jetting. There hasnt been a rental car for the past 30 years that has a carburetor
if your marine service place you took the boat to wont re-jet your carb, they are not doing you a service. find a real mechanic that understands motors. your carb should drop down a few jet sizes just like the factory manual says you should do based on your elevation. the manual also says to drop down in pitch too. the only thing you can "adjust" on a carburetor is idle mixture and idle speed. everything else requires replacing one jet or metering rod for a different jet or metering rod
Im not going fishing, however I am going boating this weekend. And I will be burning about 100 worth of fuel
I would never wish bad luck on anyone. In fact, when I hear about bad luck I sympathize.
However, in my case, it would be impossible for this problem to ever happen to me. I know enough to never even use 1 year old fuel, and, like everyone reading this thread, I know enough to rejet if I ever had to move to the mountains.
(BTW, it was an awesome trip. Caught the largest Redfin I ever saw, and witnessed a 40' COE workboat hit a rock reef and tear up the bottom half of both of his Yami outboards. Talk about bad luck....)
