nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,100
Finally splashed my 3.7L --> 4.3L swap today. A few issues remain, but the biggest is that I'm running lean. Seems to run fine up until about 2500 RPM, but starts surging after that and eventually starts backfiring if I push it. Doesn't matter if I ramp up slow or fast. Interestingly, it gets on plane without stumbling badly. Doesn't do it smoothly, but doesn't backfire either. Again, I can hammer it or go slowly, and it planes ok. Plug after chopping and running at around 2500 rpm is attached.
The block is an '01, with the peripherals from an '89. I put on a new manifold, 4 bbl Edelbrock 1409. Carter electric fuel pump.
Carb was setup per Rick Stephens guidance, running basically the same setup:
.095 (part#1426) primary jets
.092 (part#1425) secondary jets
.065" x .057" (part number 1461) meter rods
7" pink step up springs
Problem is i have NO idea where the issue is. It can literally be anywhere in the fuel system, since everything past the gas tank is new or new to me.
1. Old (ish) gas. No water in the filter, but it wasn't nice and clear either. I put in 5 gallons (27 gal tank) of fresh before going. I don't think this is it, but I'm going to go out with a jerry can next.
2. Carb. Oy. Bought the carb used, so strike one. A bit of a crap shoot on how to set it up, but used the jetting and metering that a few others have used with success. But it's never been used on this boat. Strike 2.
3. Fuel pump. It was only putting out 2.5-3 psi when installed. No idea if it's running out of gas (ha ha) at higher rpm. No easy way to tee a gauge into my hard line to see what it's doing when I'm running, though I don't know what I'd be looking for anyway. 2.5 psi and lean condition might be enough to get yet another new pump, right? I'll need to put together a rubber line for testing, but it will have to wait till I get home.
Any other suggestions welcome. Should I swap in some larger jets? Fatter springs? The edelbrock tuning guide is set up for a 5.0 which is allegedly too rich for this motor. I'm not sure which order I should start swapping things, a 4bbl carb is new territory for me.
