Mybadomen
Thread starter- Joined
- Aug 22, 2020
- 11
Hi guys and thanks for any help in advance. Before i go out and spend money on the wrong Prop i really need some help on getting the right one.
Here is the Background of the boat -
I bought this boat about 3 weeks ago. Its a 16 foot Aluminum Grumman boat bow rider with full interior ,windshield ,on board gas tank , wooden floors and other stuff that adds weight so i think its heavier then i would think for a 16 foot aluminum boat. The person i bought the boat from said it came with a 40hpthat went bad so they bought a used 1987 55 hp Evinrude 2 cylinder 2 stroke engine. From what he told me he never had any power in the boat since the engine swap and is the reason he actually sold the boat to me. I went through everything Carbs , ignition ,everything i could think of and the boat would not go over 3000 rpm. with me alone in it i think i got to max 3200 rpm roughly. So i was thinking a cylinder was cutting out or main jets were clogged but nothing fixed it . The boat goes out and runs all day perfect accept for the fact i cannot get over 3000 rpm which means i cant even get on plane,This is very dangerous where i use the boat because its hard to get through under the bridges in my town when the current is running and i have no power . anyay before i write a whole book here trying to explain i will get to the point.
- 1987 Grumman16 foot Bow rider aluminum boat with full interior
- 1978 Evinrude 55hp 2 cylinder 2 stroke engine with 12 x 17 prop
- In Neutral the engine will hit 5500 rpm which is what it should max out at.
- In gear Max rpm is 3000 rpm.
- i usually have a full boat . 6 adults but even alone in boat is max 3200 rpm and cant plane.
- the prop on the boat now is a 12 x 17 and looks way newer then the engine so i would say its been replaced.
So here is where i am totally confused . and scared of buying the wrong prop.
What i read and im sure im wrong is that
- changing the diameter of the prop by 1 inch = 500rpm ?
- changing the pitch of the prop by 1 = 200 rpm ?
- i need 2500 more rpm tp reach max rpm
According to that math this is what i come up with which i dont think is right?
- 12 x 10 prop would be roughly 4200 rpm wot ?
- 11 x 10 prop would be 4700 rpm?
- 10 x 10 prop would be 5200 rpm ?
- if stayed at 12 inch diameter i would need a pitch of only 7 pitch which dont sound right ?
I am totally confused on what prop i need to achieve 5500 rpm which is 2500 rpm more that i need .
I really hope someone can shine some light on this for me because i went to a couple stores and they i got 3 different opinions on sizes .But it still dont add up . the math dont at least .
1) 1 recommended either a 13 x 11 ? thats an increase in diameter and drop in pitch but i dont see how they get 5500 rpm by doing that ?
2) another shop recommended 11 3/4 x 13 ? that sounds closer but still not 5500 rpm ?
3) and last shop recommended 12 x 13 ? to me that only on paper would bring the boat to 3800 RPM ?
I am so Lost . Please help .
Thanks Dave
Thanks Dave
