dlogvine
Master Chief Petty Officer
Thread starter- Joined
- May 4, 2015
- 839
I've been trying to figure out why my cutoff switch does not work when im shifting gears. I tried to push it manually and it shuts the engine without any problems.
The engine I am using on 2006 Baja Islander 202 is an older rebuilt 1993 Mercruiser 5.0 V8. I looked at the original shift bracket that came with the engine and since I tried almost everything possible, and looks like when I am shifting the gear lever (this model of Baja Islander has dual lever shifter, one for gears another one for gas) it does not push enough on the bracket to engage the shutoff switch.
So my questions are
1. does this dual lever remote control require different shift plate?
2. Do i need the shift assist for this shift plate?
3. Could the problem be in the shift plate itself and should I try to change it?
Thank you.
So my questions are
Thank you.
