dlogvine
Master Chief Petty Officer
Thread starter- Joined
- May 4, 2015
- 839
I'm replacing a lower shifter cable on Mercruiser 5.0 with Alpha one gen 2 outdrive. I used a snake line to route the sleeve and tried to let it sit with as few bends as possible. However when I tried to thread the core cable it gets stuck right after the transom plate when the sleeve is making the sharpest turn. If I untie the cable nut attaching the sleeve to the bellows and push the sleeve back by a couple inches I am able to push the core cable forward and then move the sleeve all the way in but then with the core cable in I'm not able to tie the sleeve to the bellows housing.
Any tricks to do it? Maybe using some kind of a crow foot wrench?
