acetone
piers
is it ok to clean the odd stain etc. from fiberglass/ gel coat? thanks........2600
ondarvr
Re: acetone
Yes, it may dull the finish though, so you might need to rewax those areas.
Boomyal
Re: acetone
Whoa 2600. Acetone will soften and distort your gel coat. I wouldn't use it!
ondarvr
Re: acetone
Don't worry, cleaning gel coat with acetone won't hurt it. If you were to leave an acetone soaked rag on gel coat it may cause problems, but just cleaning it won't do any damage.
piers
Re: acetone
I have used it a couple of times....seems to work well.I had used laquer thinner once.Is that any better or worse.I am changing my thru hulls right now and I thought I had read somewhere to clean and prep the area around the thru hull hole prior to putting in the new one with the bedding compound , you used acetone.I also heard it was ok for the odd stain....just wanted to make sure.<br /><br /> 2600
Chief101
Re: acetone
Acetone is fine for cleaning gel coat. No worries. I don't know about laquer thinner, but given a choice I would stick with the acetone. Chief
piers
Re: acetone
thanks chief always better to be sure....2600
