1987 Mercruiser 3.0 No Spark
jshark
I am restoring a 1987 Four Winns Horizon 170 and have no spark. I replaced the coil.
achris
More fish than mountain goat
Need a bit more than '1987'. What is the engine? Title says 3 litre, but you say '170'. 3litre was 130 or 140hp. The 170hp was a 3.7litre. Please post your engine serial number, and what ignition system you have (points, DDIS, EST)...
Chris.....
jshark
My apologies sir. The 170 is the designation for a 17” boat. It’s an in-line 3.0 130HP with points.
The engine serial number is B515180.
Thanks in advance!
jshark
Have 12 volts, both sides of the new coil and at the points. Could it just be a bad condenser?
Ayuh,...... Welcome Aboard,........ ya need voltage at the movin' side of the points, 'n ground at the mounted side, 'n the points should be sanded, or replace,.....
jshark
Are there and other functions of this system that would kill the spark outside of the coil, distributor, etc? I’ve read some posts about the tach not working?
Ayuh,..... So disconnect the tach wire at the coil to test that theory,....
achris
With the points closed, measure the voltage on both sides of the coil. Should be 0v on the coil negative and about 8v on coil positive...
What do you have?
Chris....
achris
The points aren't closing electrically. Take them out and clean the contact faces...
Chris....
jshark
Chris,
I did as you suggested. I figured I may as well just replace it all? When I pulled the points they were completely burned through on the on side. Replaced points & condenser, cap, rotor, wires. Have great spark!!
Thank you for your help sir!!!
jshark
And I had 7v on the positive side and .4 on the negative. Could just be my tester?
