Merc fuel pump discontinued??
Mikeyme84
Hello
trying to find fuel pump 861155-4 and having zero luck.
does anyone know if this part was replaced by another?
2004 Merc 5.7 TKS 2bbl carb
serial 0W301089
ThomW
When i searched the fuel pump for that serial number--1998 and newer 5.7's--the part number i got was 861155A3.
That part seems available online or at iBoats' website.
its a $50 Carter/Airtex fuel pump with a $1 packard connector on the end of the wires sold as a $230 pump nearly everywhere
achris
More fish than mountain goat
Where did you get your original part number from? Because, it's wrong.
Chris.......
achris
It’s right on the fuel pump.
Numbers printed on or cast into a part are not the number that's used by the 'parts department'... You need to look at the part number in the parts manual to find the correct number.
Chris.........
