Need help with flywheel question
Tylor2020
I need to replace flywheel on my 90 welcraft mercruiser 4.3 v6 no fuel injection. Where can I get one. Can you use a automotive flywheel on these motors. New to the website I hope ok to post here.
Bt Doctur
no such thing as marine flywheel but all you need is the ring gear
Fun Times
Hi there, welcome to iboats and you're in the correct sub-forum to post this Mercruiser question.:thumb:
When searching for Mercruiser parts it's always best to have/provide your engine serial number to help locate the right parts and help reduce any guess work of if it will fit your engine, stern drive or transom assembly applications should there be any changes.
That mentioned, I believe I found your flywheel part number by year but it seems to be no longer available....The OEM part number is 222-9518 which now would become the starting point to finding another one which probably would be a "used" one such as this one, https://www.nlamarine.com/products/...3lx-alpha-one-262cid-85-93?variant=1110579788
The flywheel is item number 6 under the parts guide that ought to be for your engine year range but again engine serial number is always best to be for sure, https://www.mercruiserparts.com/bam/subassembly/31478/951/190
Search the OEM part number online for others if desired.
https://www.mercruiserparts.com/4-3l-2-bbl-gm-262-v-6-1988-1992-0b7
That mentioned, should the flywheel ring gear teeth be damaged, you could also search out say online for a new 1990 Mercruiser V6 flywheel "Ring Gear" to install vs buying the whole flywheel....It takes heat to change out the ring gear though.
Hope this helps, good luck.
nola mike
Find the gm part, looks like
(14088648) for the flywheel and (3991408) for the ring gear
Tylor2020
How hard is it to replace just the ring. Never did anything like this. I got buddy helping this weekend to to remove the motor.
First, spend the $15 and buy a ring gear, there are only two choices....153 tooth or 168 tooth
with the flywheel off
Use a drift to knock the old ring gear off
Put new ring gear in oven at 300
Clean the flywheel with a wire brush
Put flywheel in the freezer
Drink a beer
Pull flywheel from freezer and set on bench
Pull ring gear from oven and drop on flywheel
Once the temps normalize, tack weld if you want, then install flywheel
