chuongnino
Thread starter- Joined
- May 24, 2020
- 10
Recently my boat has been making a knocking noise. I took the belts off and try rotate the pulleys one by one. The water circulation pump was making just a little noise and super rusty so I jumped into the conclusion it was the cause. I replaced it with a new one and still the noise is there. I took the belts off trying to determine where is the noise again. With all belts off, the crankshaft/harmonic balancer was making that noise. Could someone help me what should I test/do next? I am trying not to break the bank bringing it to a shop if I can fix this myself. Thank you in advance.
The video shows the noise for your reference. With all belts off the noise is still the same. I run the engine on muff and within short amount of time only.
