1967 Glasspar Citation
Dboat1
I got a 1967 Glasspar Citation from my uncle. The boat has been sitting down for a while. I tried to start the boat today after replacing the battery and the spark plugs but it did not start. I replace the fuel hose connected to the fuel tank since it was damage as well. I turned it on but it seems like fuel is not getting to the carburetor. Could this be that I have a bad fuel pump?
Carl1783
I would clean the carb. Have you tried pouring fuel directly into the carb and starting?
Ayuh,..... Welcome Aboard,...... What motor,..?? by whom,..??..??
The fuel pump, 'n sediment bowl in the picture is By-passed,.... No way it'll pump fuel that way,....
Dboat1
Thank you for your post Carl1783, I am new to this so I will try doing that as soon as I have a chance this week and I will let you know.
Dboat1
Hi Bondo and thanks, it is supposed to be a converted chevy 4 cylinder Nova motor. Should I just removed the sediment bowl and connect the fuel filter straight to the fuel pump?
mr 88
Probably should be in the Mercruiser forum.as it engine related. Have you pulled a plug and turned it over to see if your getting spark? Does the engine have points,which could be pitted and not opening , or a converted Petronix system? If you turn it over with the fuel line that connects to the carb removed ,with a jar to collect the fuel ,is there fuel flow. Could be your neutral safety switch, could be a plugged jet in the carb. Need more info and you should eliminate parts that are working to figure out why it's not firing.
Dboat1
Thank you Mr 88, I will try that tomorrow and I will keep you informed of any progress made. Very much appreciated.
