Danthehitman
Thread starter- Joined
- May 19, 2020
- 42
Hi everyone and thanks in advance for any advice you may have!
So, I've only only this boat as of this year, had it out for the 5th time this last weekend. I'm noticing it starts immediately when out of the water (using water-muffs, of course). I always test-start before heading out on the road. I have been using the 5-8 second prime after pressurizing the fuel-line and it starts like a charm. For some reason, once it's in the water, at launch and/or after sitting for 10 minutes on the water, it refuses to start at which time I have to use starting-fluid, then it'll start. I'm struggling to figure out what the problem is.
I notice the fuel pressure bulb behaves differently, typically at launch, like it doesn't want to pressurize. Other times, after sitting for 10 minutes, I can pressurize the bulb but still have no-start condition.
I've GOT to figure this out. Fuel pressure bulb is new, ruled that out.
Thanks, again.
Thanks, again.
