Devildog891
- Jul 1, 2012
- 10
Apologies if this has been asked over and over. I screwedup the other day and hooked my battery up backwards. Knew I blew the 90amp fuse so I replaced it. Also replaced the slave solenoid because it appeared to have seen better days. Had my starter tested, and didn't have any issue. Ran my test light through all of the ignition components. Checked the dash, did not blow any fuses there. Checked the ignition switch and i didnt have power anywhere so I replaced that. Mechanic suggested trying to start it through the yellow wire and purple wire, no luck. I am suspecting a hidden fuse some where and I was hoping someone here may know the location? Boat is a 2000 bayliner capri 1950 with the 3.0 mercruiser. Any and all help would be greatly appreciated! TIA!
