kramerpage
Thread starter- Joined
- Jul 26, 2010
- 447
while trolling last weekend my warning alert started an intermittent beep, beep sound at the helm.
This motor has the oil injection blocked off kit using a 50 to 1 mix in the main fuel tank. The lubalert as mercury calls it or oil alert module is still wired to green going to coil #2, tan/blue going to pin #3 on the engine harness and finally purple going to #2 pin on engine harness.
When traveling to my fishing spot the RPM on the tach was 300 higher than normal. then I shut it off and restarted and it was back to 1000 at idle instead of 1300. I trolled for 2 hours at idle around 650 to 700 RPM no issues until the beeping started. I went right to the pisser to check water flow and it was normal. I placed my hand under it and it was hot but normal to me. I went ahead and ran it back to the dock at 4500 rpm and it stopped and then started again a few times during the 5 mile run.
Could this be a Voltage regulator issue causing this? the tachometer issue is new and the horn issue is new. I had the marina place new stats and water pump this spring which They do every 3 years. Motor starts and runs great. Thanks for any insight.
Kramer
Kramer
