landover50
- Jul 29, 2016
- 33
1990 merceriser 5.7l
I recently bought a boat. He stated he had recently changed the bellows himself so I wanted to check to make sure there was no water in it and instead of finding water I found a bunch of gear oil. He said he has never had gear oil in it before and this would have happened in only a couple trips in the water.
I'm not sure if I believe him but if he is telling the truth, is it normal for the yoke seal to go bad that fast? Or is this a symptom of something else?
I pressurized the outdrive and sprayed soapy water around the seal and you can see in the picture it is producing bubbles. I just wanted to get some opinions from the experts on here and if it is a yoke seal, some tips on how to proceed. Also if there is anything else I should be looking for and replacing while I'm at it. I've been doing my reading (lots on the forums here, excellent info) and watching videos as well. Not an expert but handy enough to get most things done.
Thanks in advance for any help....
