2003 searay sundeck 220
Bc200315
I have a searay sundeck 220 2003 model mercruiser 5.0 mpi with bravo 3 outdrive . I recently took it out and ran great for about 2 hrs then started cutting in and out for about 30 secs and shut off. I waited around a few mins and tried to start it and it would run with little throttle for about 3 to 4 mins and cut out and die again. I did this about 15 times to get it to the dock. Brought it home and replaced both fuel filter and fuel/water separator and hooked it up to the water hose to run it. It cranked right up and ran for about 3 to 4 mins fine and died. The IAC is good , already checked that . Any ideas or thoughts.
I have a searay sundeck 220 2003 model. I recently took it out and ran great for about 2 hrs then started cutting in and out for about 30 secs and shut off. I waited around a few mins and tried to start it and it would run with little throttle for about 3 to 4 mins and cut out and die again. I did this about 15 times to get it to the dock. Brought it home and replaced both fuel filter and fuel/water separator and hooked it up to the water hose to run it. It cranked right up and ran for about 3 to 4 mins fine and died. The IAC is good , already checked that . Any ideas or thoughts.
Ayuh,..... Welcome Aboard,..... In this forum, we don't give a crap what the boat is, But,.....
We have to know what the motor, 'n drive are,..... Serial numbers always help,.....
Bc200315
Mercruiser 5.0 mpi is the motor, om646146 is the serial number, bravo 3 outdrive
