2000 alpha v8 no power on purple wire cranking
scoflaw
Ensign
Not my boat. 12volts key on. 0 cranking. Fires up hot wiring purple. Any likely culprits?
alldodge
More info please. What 2000 V8, carb, EFI other?
Ayuh,..... Look to the outside tiny terminal on the starter's solenoid,.....
That terminal feeds battery voltage to the ignition, Only while crankin' on the starter,.....
scoflaw
Ensign
Thanks, will advise owner. Your talkin solenoid on the starter, right. Some manuals refer to the slave as a starter solenoid.
alldodge
Like pulling teeth I guess
You said 12V on the purple wire goes to zero when the starter is engaged. The EFI does not transfer power from the starter to the fuel pump while the starter is engaged. In any case power is removed from the purple wire.
Where is the 12V going to zero being measured?
achris
More fish than mountain goat
Sounds like a faulty key switch... If 12v is on the purple when key ON, but drops to zero when key moved to START, that can only be the key switch...
scoflaw
Ensign
he has no spark when cranking and the gauges die, not sure where he is measuring from. Has power to the r/p at the key switch.. He has tried 3 different key switches. Don't have his engine number, the motor has the electric carb with 2 throttle bodies on top. Was thinking shift interrupt or neutral safety but don't have a wiring diagram for his engine.
achris
... the motor has the electric carb with 2 throttle bodies on top. ....
???? WHAT ???? :facepalm:
Neutral safety stops the engine cranking. So it's not that.
Shift interrupt just stops the spark being produced, doesn't mess with the voltage on the purple or the gauges.
scoflaw
Ensign
I just sent him a note about what kind of switches he's been using. Doesn't make sense that he loses power to purple cranking. Thanks for the thoughts
alldodge
I'm going to assume power on the purple is not being lost at the key.
On a EFI motor Purple changes to Pink when it connects to the EFI harness. Pink energizes the MPR which transfers power to all other circuits including coil.
I'm thinking corrosion in the EFI harness connector or MPR or main power connector
Click image for larger version  Name:	efi power.jpg Views:	1 Size:	60.4 KB ID:	10877730
scoflaw
Ensign
I just told him to check continuity at the switch between Batt. and ign. when the key is in the start position. Sure sounds like a switch problem to me. He's got power to the r/p at the switch and power leaves the switch on the purple wire and next in line are the gauges. So his gauges die in the crank position, so not sure how corrosion down the line would effect power to the gauges.
alldodge
Always good to have more info when asking a question to others. Good luck
scoflaw
Ensign
Resolved.... Jackass had the ign. switch wired wrong. just can't fix stupid. Thanks for listening
