rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
J150vxsi non ficht, non EMM or computer
Did some testing tonight with vacuum guages for an issue I was having. Was hoping someone could help interprete my observations and test info.
Background: Was getting a Check Engine light on PORT motor only.These motors have no computer. Tach has 4 lights, the one coming on is CHECK ENG...Which means Fuel restriction. Was happening at Hi Speed, then at Med speed, then at near idle into port. And sometimes just putting the key to "on" without starting motor..it would come on.
Tonight went to Marina, did the following:
1. Removed all hoses, connections, primer bulbs and replaced..Down to the Tank pickup. Removed Previous owners splices and joiners. Opened new Racor filters, all good. Removed motor fuel filters to inspect all good. Found No issues anywhere.
2. Installed vacuum gauges on T's, between motors and primer bulb (this is twin engines). Used Clear hose up to engine input to look for air bubbles etc.
Started both motors and I was surprised to see basically the same thing on each motor. Was expecting to see motor in question with higher vacuum, or at least something different.
On each engine I saw, very low vacuum. See pics. On the scale, i'm guessing less than 1inch..They would come up a little depending on how I held the T'd-in gauge. Tight connections, all clamped well.
I then brought each motor up to 2500 to 3k at the dock, in the water (briefly)....Saw NO change in Vacuum at all.
I then pinched the Port (motor in question) fuel line before the primer, and I could make the gauge go up. When it got to about 4 in, it set off the Check Eng lite, and alarm. it went out in 15-20 seconds after releasing the blockage.
Then I did the same thing on Starboard (non-issue motor), same...It rose up and alarmed when it hit about 4-5in.
I"m not really sure what to make of all this...I thought I would see 3,4,5 inches of vacuum typically but dont know.
Does a low vacuum, meaning fuel is flowing pretty much unrestricted.
I'm leaving gauges attached to do a test cruise under load, Saturday to see how the gauges look.
**My suspicion is at higher RPM its going to rise ( didnt see this at the dock at 2500-3000 however) to near 4-5 inches and set the alarm.
**What is the normal low RPM readings??
** What should it normally go to at higher RPM under load??
