rjg236
Thread starter- Joined
- Aug 11, 2015
- 17
Had a great day last week when after installing a new spark amplifier, flushing the lower unit with some fresh type c, priming with some fresh premium she coughed and sputtered to life after 8 years of sitting. Better yet when neutral and reverse engaged perfectly under remote control.
However I see no water exiting through the outlet just above the cavitation plate. I've checked the thermostat and it functions in a saucepan with hot water. I've let the motor run for a few minutes without seeing evidence of water exiting. Pretty sure it's getting up to temp. Can anyone explain the proper operation of the water outlet on this motor. There appears to pee tube on this motor per the service manual and I want to make sure my next step is to crack open the lower unit and feed wires. Because aside from the water circ problem everything is working well.
Appreciate any info you guys might have.
