intheworks1
Thread starter- Joined
- Apr 10, 2020
- 3
So Iv searched here and other places for days and cant find an answer. I have a 1973 Meyers semi v hull 12ft aluminum boat with a 1981 Johnson seahorse 7.5.....Motor and boat run great I just have one issue. Once the boat gets to full speed there is a very noticeable humming chopping sound (not a high pitch sound) that seems to be coming from the prop...sort of the noise you get when you drive over the line on the high way and hit the safety rumble strips only no vibration . The sound goes away at slower speed once water raises back up around the lower unit and it also is not effected by revs. Im wondering if the prop isnt low enough in the water or what. I look at it while going and it seems to be at normal height from what Iv seen online. Thanks
