Is foam flotation a legal requirement?
Re: Is foam flotation a legal requirement?
Now once the foam has been fibre glassed over. The foam will be completed sealed and no water will be able to penertrate the foam.
Ayuh,.............. You just Keep telling yourself That........... I Know Better.......<br /><br />There's No Such Thing as a Sealed Completely Waterproof compartment on Any Boat.........<br /><br />BTW,.............<br />
Only If you're a Boat Manufacturer.............
billh1963
I'm surprised that anyone would advocate not using flotation...especially foam. Yes, it's a pain when older foam gets wet and saturated which can add a lot of weight to a boat. But the newer foams won't hold water like the older foams did.<br /><br />I plan on replacing the foam in my Aquasport restoration. If properly applied it does add integrity to the hull as well as some peace of mind.<br /><br />Maybe sinking in a small lake isn't as big a deal as sinking offshore. But, I know if my boat had a problem I'd definitely want something to hold on to!
budbecks
Even if the foam does become water tight through completely fbireglassing the whole lot. It will still make the whole structure of the boat stronger will it not.<br /><br />Maybe different boats vary but i have done quite a few fibreglass roofs in my time and i know once that stuff is placed and installed correctly that overall final product is incredibally strong is it not.<br /><br />I know in my boat once it has been installed the hull will be made a whole lot stronger. Not that it needs more strength mind.
santa666
Yeah guys, Sorry to break the foamers hearts I'm not going with foam.
santa666
Buttanic
I do not like foam.It will get wet no matter what anyone says. If I had to dig 500 pounds of wet foam out of a boat I am fixing I sure wouldn't put it back in. Wise choise santa666.
brownies
Coming from a "relatively" small, but, well know boat manufacturer, With a long history and strong following.<br /> "If we are building a boat for ourselves (one of our employees or owners), we NEVER install floatation foam."<br /> Until I hear differently from a better source, I guess I'm a firm beleiver in no foam when given the choice.<br /> Some boat builders used to lay loose chunks of styrofoam in the hulls before laying the floor. Over time, I think that would turn into a really "squeeky" ride???
brownies
IF you do use floatation. It will mean that you think no water can get to it, therefore, Do everything you can to the point of overkill to seal the openings / areas where the foam is applied.<br /> <br /> If you don't use floatation, It will mean that you think water CAN get to it, therefore, Do not SEAL those areas completely....that way when water gets in there, it can get out. AND if water can get out, air will be able to get in to help dry out the moisture as well.
Excellent Point...........<br /><br />Limber Holes haven't been mentioned in awhile......<br /><br />You should have Good Drainage from All points in the Boat, to the Bilgepumps.......<br /><br />You Need Limberholes Thru/ Under all your Stringers,+ Bulkheads so that water can Drain......... ;)
brownies
You can seal the edges of the holes also. <br />I've not been worried about being able to seal off a stringer. You can see three sides of it, and get to it with glass and/or anything you want to use to seal/finish it.<br /> If you drill a limber hole, you can use a thru hull fitting to seal the wood edge that the drill bit found, or, you can glass the edge.<br /> <br /> When you put the floor back down though, it's hard to know if you ever actually sealed it "completely" against the stringers. (that's why I don't put the floatation back in there)...also, if the floor wood stays wet for very long, it will seep.<br /><br /> IF I knew without any question or doubt that I could seal those cavities that came with floatation in them, I'd probably put the stuff back in there. BUT, since boat manufactureres can't do it, doubt I could either.
jtexas
Sealing edges of holes...one way is to drill the hole slightly larger than you need, fill it with epoxy, then drill the hole in the epoxy.
tashasdaddy
just looked at a 1979 18' bonita deep V. it had obviously been waterlogged before. they cut the floor out remove foam. finish bu putting 1/2 plywood over it and painted. there is nothing left of the stringer or transom. a great hull, great galvanized trailer. they want $500. i think that is too much. no motor, rated 135hp.
brownies
Too much $ I'd agree unless you needed a trailer. Looks like they didn't catch it in time.<br /> I like the epoxy idea.
santa666
QUOTE: If you don't use floatation, It will mean that you think water CAN get to it, therefore, Do not SEAL those areas completely....that way when water gets in there, it can get out. AND if water can get out, air will be able to get in to help dry out the moisture as well.<br /><br />That's pretty much right. <br /><br />I do feel that water WILL, not CAN get to it, and that I WILL seal the edges of the cabin sole/hull, but have clear drainage (underneath) and that...<br /><br />WHEN water gets in there, it WILL get (pushed)out. (by me): QUOTE "air will be able to get in to help dry out the moisture as well."<br /><br /><br />THEREFORE, the boat will have a built in positive airflow system- To wit:<br /><br />I am building in a sealed bearing marine grade biscuit fan (on a timer) that will force (statiscally) drier air from outside into an opening up inside the upper front of the bow through the stringer and bilge area and out into the atmosphere in the open bilge well to evaporate. <br /><br />This boat is to be a trailer boat and will be stored/drained on an incline comfort me greatly in my thought of having a long-term viable boat. <br />I'll also fill each floor screw hole with resin as well as have sealed drainage holes in the stringers and bulkheads. <br /><br />Couple these with my intent to use a fiberglass sealant system (like interlux 2000e and bilgecote) INSIDE the hull before final assembly, I'll NEVER have to do sringers/transom/floor again. <br /><br />This was a free boat that my dad bought when we were kids (1968) We've had a TON of fun on it. I recently bought a '96 Mercury 115. So, there's sentimental value, and its a labor of love.<br /><br />So, its going to be like that TV rotisserie oven:<br />JUST SET IT, AND FORGET IT-
BillP
Not to burst anyone's bubble but after you cut up a couple of boats it gets evident that any and all foam can stay wet for years. Ask any shop that does stringer/floor jobs for a living. Closed cell just takes longer to get saturated but it sucks water too. Ask the folks who make foam (Clark is a big player) if you need proof but don't rely on boat advertising. Water that drips down or splashes gets trapped in cells that won't drain. You have to turn the boat upside down to drain them. Once foam gets really saturated it stays wet way beyond whatever drains naturally. Air drying sounds good but in practice doesn't do much. I cut a boat up that had the drain plug open and bow pointed in the air for approx 9 yrs. It was stored under roof where rain couldn't hit it and the foam stayed wet. <br /><br />The way to fully evacuate water from the foam is to pull a vacuum. It doesn't take much to pull the water out but it is about the only way to get it throughly dry. We used vacuum to dry out foam insulation on commercial roofs. Fans take years to do what a vacuum pump takes weeks. Attach a VP to the drain plug hole and dry it that way.
santa666
To Bill P, <br />Ok, clearly you've missed the point. <br /><br />I AM NOT GOING TO FOAM. There, wrote it out. I agree with you, AND I like to beat a dead horse too. Sexual metaphors aside, I think I'm going to have a darn good boat without foam. <br /><br />Not turning of boats over, no vacuum pumps, won't have to dry it for 9 years, none of that, just fiberglass, some bilge coat and a coupla fans.
Buttanic
Interesting point about using a vacuum pump. I bet one of those big vacuum kilns they use to dry lumber in would get th job done. I am surprised someone doesn't offer that service.
There's Not really any Vacuuming going on it a Kiln,.........<br /><br />Kilns Bake lumber in Steam, to Dry the Wood...........
Buttanic
I was watching a show on TV where they were salvageing sunken logs and after they were cut into lumber they were put into a kiln that pulled a vacuum to dry the wood.<br /><br /> http://www.woodweb.com/knowledge_base/Vacuum_kiln_drying.html
surlyjoe
water doesn't boil until 30 inches of vacuum, that would prolly implode your hull...
