timothy lee
Thread starter- Joined
- Mar 17, 2020
- 4
shifted to fast now prop is slipping what to do
model rkl 25d when I shifted at high rpm from falling over after that motored over to dock at high rpm but very slow speed so will prop still spin if either of those condition are true
RKL is electric shift. It is either the prop hub, OR the clutch is slipping. Easy trouble shooting before you freak out. Check prop first. Make a mark on the plastic prop hub and another on the prop, aligned with the first mark. Run motor till suspected slippage occurs. Stop motor and check marks. If they no longer align, the hub slipped.
Oops----check drive pin first. I
