1985-1995ish Mariner 200 low speed misfire
tcpMariner
I have a 1985-1995ish v6 200 Mariner (carb) that has a misfire when it reaches approx 1500-1800rpm. The motor idles fine In and out of gear until it reaches that rpm. If accelerated quickly it misses that bad spot and runs fine. If acceleration is slower from that rpm the throttle can be to the floor while going nowhere. Spark plugs are new and gas is fresh. This motor is very powerful and responsive other than the miss at that rpm range. My guess is electrical problem. Any ideas?
Dukedog
ya need ta be a little closer with year.. big difference in blocks, 'lectrics and carbs in that span....
tcpMariner
I believe it’s a 1987-1990 block. The guy I got it from said it’s a 1995 but I doubt it. It’s a 200 power head on a 150 lower unit etc if that makes since so the serial numbers are not correct and I have not found the serial numbers on the block. They’re probably behind the power pack I believe however
Dukedog
looks ta be pre '88 2.4 200.. has two piece heads and 16 amp 'lectrics.. that pretty much rules out fuel/carb being tha problem.. 'lectric will be testy ta track down.. without being able ta touch/hear it, hard ta say where ta start...
tcpMariner
Why would that rule out fuel/carb problem? And could the high speed/low speed transition be sticking on the stator??
Dukedog
carb transitions instantly off idle.. no in-between idle circuit and run circuit... stator goes ta high side at 2500 ta 3000 roughly...
Faztbullet
The transition from low to high is done in switchboxes not stator.... Put a 1/8 gap between throttle cam and roller and see it that helps.
Run with a timing light on one plug lead at a time.---Observe spark behavior when motor has the miss.
tcpMariner
Also is there a way to do that without removing the fly wheel? If I’m following what your talking about.
tcpMariner
Never mind I see what you’re talking about. I haven’t done it yet but can you help me understand the concept behind the 1/8th gap between the cam and roller? Thanks!!
Dukedog
look here for a number.. welsh plug top of block.
