gr8shot
Thread starter- Joined
- May 30, 2019
- 73
Just about ready to start assembling a new 350 vortec motor for my 99 sea ray 190 signature. Short version of the story is the 305 that was in it wasn't winterized and the block cracked so I got the boat for very cheap. My plan from the beginning was to use the 431-811658 camshaft from the 305 in the new 350. It's slightly better than the GM vortec truck cam. Has a little higher lift and a little more duration.
I'm curious how much power I'm leaving on the table by not getting a better cam though. I know it would be a decent upgrade, but curious on a few other people's thoughts.
Mercruiser 431-811658 specs:
196/206 duration @ 0.050"
.431/.451 lift. 109LSA
The cam I have in mind, I've seen advertised on ebay as working well with 100% stock vortec heads is comp cams X4270HR
220/224 duration @ 0.050"
.474/.474 lift 111LSA
Comp cams also has one with slightly less duration, same lift and a slightly lower powerband.
I'm sure that's really pushing it on valve lift for stock vortec heads. But curious on some people's thoughts here on one vs the other.
