Texasmark
- Dec 20, 2005
- 15,067
Where did you get the 21? New or used? Seems to me something is squirrely, like maybe you have an intermittent hub slipping problem. Take it off, if it's not off already and scribe a line from the center of the hub....bronze splined area, out to the outer casting, including marking the outer casting material. Put it back on and take it out and romp on it a few times. Take it off and check your line. If it moved, get the 21 repaired (new hub) and put it back on. That should be your sweet spot on prop pitch.
