LakeSaintClair
Thread starter- Joined
- Jan 2, 2020
- 8
I have purchased a 1966 StarCraft Sunchief 22 foot outboard boat. I hope to restore it to its close to original condition as possible. I also plan to rebuild the transom and flooring.
When I purchased it, the floor had already been removed, and was impressed with the fact that it appeared very clean in the bilge area. The chine rivets and ribs appear to be in good shape. The hull appears only to have been used in fresh water, as there are no signs of corrosion. Initially, I felt very inspired to take this boat back to a complete restoration. I have some hesitations now after reading about some possible weaknesses of older Starcraft hulls.
My questions...
1). Since I found this forum, I have read about older StarCraft’s having chine cracking issues, due to ribs that didn’t overlap onto the chine seam. How much should I be concerned about this? Is there a modification that can be done to strengthen this area?
2). The boat was originally rated for 120 hp. I have a set of Johnson 70 hp outboards. Each of them weigh approximately 260 pounds. Would I be overloading the old girl if I hung the pair on the transom? I am very judicious when it comes to speed and throttle use, and would likely never run it at top end. I’m more concerned about 520 pounds of outboard hanging on the back...
Any insight you might have would be very welcome. Thank you!
My questions...
