- Mar 8, 2009
- 43,596
I think I found the correct answer ,,, now I feel really bad because it came from another forum ,,,,,The correct answer is:
88fas014-6
Thanks for looking it up, which paragraph in the spec is this listed?
88fas014-6
For the 30" label/spec of an ASV, that is the maximum height of the fuel level in the tank to the lowest part of the fuel system and is usually referenced as the "head". In other words, the valve will seal against a leak up to 30 inches below the top of the fuel level.
the spec quoted corresponds to West Marines spec:
Or which may not be needed on a lot of inboard powered boats.
It is the law that an ASV or electrically operated stop valve is used on inboard motors with permanently mounted fuel tank page 93 thru 96
https://www.uscgboating.org/assets/1...YC.1002.01.pdf
