Texasmark
- Dec 20, 2005
- 14,568
Just blindly jumping back into on this: The 1997 Merc sales brochure states 5800 rpms max with a 1.87 gearbox. Go-fast.com prop slip calculator says that your max possible speed with that running a 23P prop (may be a 24 equivalent at WOT if cupped properly) would be 68. At that speed, figure a slip of about 5% with a good fast hull and high performance SS prop and you should expect 65 on a cool day. If your cupping is working for you then the numbers are 70 and 67.
Course your engine has to be capable of delivering the RPMs under the load at those speeds but it's doable.
